JeremyD615
+1 on the Starbrite with PTFE. I use it on the Speedster and it turns out great!
Here’s what is probably a dumb question, but I’m sure one of you guys has the answer! The aftermarket flame arrestors are Ocean Pro Vortex’s, and I’ve got the caps and mesh filters off, but I can’t figure out for the life of me how these adapters/bases are fastened to the carbs! See the pic below. I assumed the studs were either threaded into the carbs or the base would slide off of the studs, but they just don’t want to turn and I can’t tap it off. I’m hoping to pull the carbs without having to hack up an Allen wrench to get into the tight spot here, but I guess I will unless someone knows a trick...
