JeremyD615
So I spent a few hours out on the water with this ski today, and it was slow enough on the lake to play around with some things to try to get my last few hundred rpm back.
I readjusted my throttle linkage before I took it out today, and there is no slack in the cable and it’s gully opening the throttle blades. I think I can scratch the cable off the list of things that could cause this...
I played with the water regulator. I started at the factory setting of three full turns out. This is where it’s been set the whole time, but I went back and verified that it was correct. Max rpm was 6310. I moved the cap to flush, and got 6320. No real change... I tried to take it three or four clicks past the factory setting, and I got 6340. I also verified that I still have water flow and that it’s restricting it at full throttle. Im pretty sure we can scratch the water regulator off of the list too.
I rebuilt both rave valves not long after I got the ski, but I couldn’t remember whether it was before or after everything went haywire. I pulled the caps, and everything appears to work correctly, but this is the only machine I’ve got with the RAVE system, so I don’t have anything to compare it to... Both valves seem to move smoothly and easily with the cap and spring off, and there is no gunk or obvious leaks in the bellows. I tried the raves turned all the way in, one turn out, and flush with no real change in max rpm. It stayed right in the mid 6300’s. I still wasn’t super confident that the raves were functioning the way they should though, because when I first had the ski on the water, before the fueling issues, it had such a strong upper-midrange and peaky feeling that just isn’t there anymore. This ski feels about the same speed as my 95XP, and that was confirmed with a GPS top speed of 51.6mph. That’s actually just slightly slower than my 720 ski.
To really rule in or out the rave valves, I pulled the caps and went for a run without them. Of course the ski sputtered and ran like crap, and it was maxing out at about 4500rpm. It wouldn’t even get all the way on plane. Then after I got it turned around and headed back to the dock, I decided to try to bounce the ski enough to unload the pump and see what happened... It got over the hump almost instantly, and revved all the way to 6600 before I ran out of room and had to let off. Eureka! It appears to be the rave valves that are causing the missing rpms, but I can’t figure out for the life of me why... I tried screwing the bellow in and out to see if I could get more travel one way or the other, with no perceptible difference, so I screwed them back hand-tight. Does anyone have any insight into what would cause the raves to not open with the caps on, even though they are clean, have new bellows and O-Rings, and move freely when I push and pull on them by hand? This is my last performance gremlin to deal with and the ski will be ready for me to get back into the cosmetics, so hopefully it’s something I’m just missing.
