dannyual767
I have two 96 XPs. One of them is slow to crank. When I press the red start button I can hear the solenoid and it sounds like the starter engages the flywheel but it just stops right there for about 1/2-1 second. Then it turns the motor over and fires the engine 100% of the time. It is a very unnerving feeling to be out on the water and go to start the ski and it acts like the battery is dead. It's not dead and as long as you keep the red starter button pushed for 1-2 secs, the ski starts up every time.
My wife rode this ski a lot last summer but it made her very nervous and she didn't want to shut the ski down out on the water. This year I decided to replace parts to see if I could fix it. So far I've failed :facepalm: .
Here are two videos with sound so you can hear what I'm trying to explain in words. The first one is with me using the red start/stop switch and the second is with me bypassing that switch. The engine was not primed to ensure that it wouldn't actually start.
[video]http://smg.photobucket.com/user/dannyual767/media/IMG_03871.mp4.html[/video]
[video]http://smg.photobucket.com/user/dannyual767/media/IMG_03861-1.mp4.html[/video]
Here is a laundry list of what I've done:
1. Replaced the AGM battery with the AGM battery out of the other XP that cranks normal. No difference.
I even paralleled two AGM batteries and it made no difference.
2. Cannibalized the known good starter out of the other XP. No difference.
3. Swapped in the known good solenoid from the other XP. No difference.
4. Replaced all three battery cables (2 pos, 1 neg) with known good cables from the other XP. No difference.
5. Bypassed the red start/stop switch with a toggle switch wired to the battery and solenoid. No difference :banghead: !
If this were a car engine, I'd say that I've got the initial ignition timing set too far advanced.
I really want to fix whatever is causing this slow/delayed cranking. Please give me your thoughts but keep in mind my laundry list above. Thanks, guys!
And yes, I know I've got a serious mildew problem on my handlebar cover!
