95 GTS Trouble Starting
stuarttgrant
Hi,
I have a 95 GTS that has been giving me trouble when trying to start. For some reason giving it any gas or choke seems to make it not want to start, but if I hold the starter down for a while with no gas it eventually starts. After it runs for a while there is no problem restarting, but when it sits for a few hours I have the same trouble starting. Any clue as to why it does this.
THANKS!
I would check basics first...what is the compression? You'll need a compression tester. Go to Auto Zone. I think they sell for like $25.00. The compression gage, will screw in the cylinder head in place of the spark plugs. To test compression, remove both spark plugs. Place spark plug caps on the plug cap studs near the cylinder head to ground the empty caps. This completes the circuit of the ignition electrical system and prevents any electrical problems from the caps being un grounded. Using the correct adapter for the threaded end of the tester,( same length of the spark plug threads length)screw in the tester in one plug hole. Hold the throttle wide open. Push the start button. Watch the compression gauge, when it peaks out at the most compression, let go the start button. Read the psi number. I would do it 3 times to be sure it is accurate. Check both cylinders the same way. The ideal compression is 150 psi per cylinder. If it is less, it's not a problem as long as they are close to being the same. If the psi is less than 90 it might need be time for a tear down and a rebuild. If the psi in 1 cylinder is say 140 psi and the other is 80 psi you need to tear down and repair. This difference is a lot and there is a problem.
It sounds like you need to remove the carburetors and clean them. If you're careful and don't tear or damage the diaphragms you won't need to buy a rebuild kit. Pay attention to the internal filters too. If you have gray fuel lines you need to replace them with black fuel lines available from auto parts stores like Auto Zone. Measure the length you need and bring a sample with you so you get the correct size. Replace one at a time so you don’t get them mixed up. If you need clamps replace them too. Use small stainless steel clamps also from the auto parts store.
This is info is for starters I hope this helps out.
Karl
