Man what a cherry!! Nice PU man!!
Sadly it does. Look at your old fuel lines. I think about half of the line says 8mm which is 5/16". The fuel selector knob is for sure 5/16" on all of them and half of the ones on the tank sender are 5/16" too. Sorry to be the bearer of bad news lol
I was wondering that myself, why in the world did they feel the need to change to 5/16 lines on the 99 whenever the 1/4 worked perfectly in the other 787 x4's??? Annoying
Agreed, very nice. That seat alone is amazing. I dont see one knick or tear.
want a mint xp to match? found this today on cl and thought of your spx http://sandiego.craigslist.org/nsd/boa/4553367078.html
The funny thing is the 97 SPX making the same run in the same water beside the 99 doesn't porpoise at all. I might try adjusting the linkage on the trim to make it go to a lower setting.I put a set of R&D trim tabs on mine, and it rides soooo much smoother. So people say that it makes it porpoise more, but it doesn't. It has helped out immensely and makes it so much more fun to ride.
make sure your accelerator pump is squirting like it should. a lot of them clog up or a check valve doesn't do what its supposed to. also the jets need to squirt at 13psi, lower and you get too much fuel, higher and not enough.
