M mpap New Member Jun 23, 2009 #1 Engine won't turnover, been running fine. Replaced the battery same thing just hums. Should the flywheel turn freely when the motor is off?
A andrei New Member Jun 23, 2009 #2 engine will not turn over Possible problem leaking mian oil seal on engine causes the piston to freeze eventualy freezes solid then requires reb uild of the engine seal costly very costly
