DeFreitas Enterprises
Well, we don't need to telly you to stop using that oil and use the correct one.
I'm turning into a believer on not using the cheapo oil. The difficulty is there are so many both conflicting advice in the mechanic / mechanical world, and also "wives tale" things that get passed along as fact but really are either things of the past or no longer applicable. Weeding out the misinformation and establishing a view point for oneself, while avoiding being ignorant and messing things up is a lifelong journey.
Are you still supplying oil to the rotary gear sump?
Not sure what this rotary gear sump is that you refer to. One of the first things I did after purchasing was rigorously read the shop manual, since I have never owned a PWC. I'm pretty experienced with 2 and 4 strokes and wrenching various machinery but like I said never owned a boat.
What I found for lubrication was that there is a counterbalance shaft which sits in a small amount (I believe 30 mL off memory but don't quote me) of motor oil. Also the impeller has an oil housing as well. But those were the only two I found in the manual, and like the general tune up I was putting that off until the end of the season. It might be stupid, but with 10+ motorcycles, countless equipment for work, and being slammed with solar clients I just can't find time to wrench on the ski now, when all was well and good. I may regret that later, but it is a decision I am rolling with. I'll have to lookup the rotary gear sump.
Dumping oil into the gas tank is not the way you do pre-mix, you could end up sucking up oil off the bottom of the tank.
hahaha I know I know. My method of choice is a few gallons at a time, but this fill up I had half a tank left already, so I was lazy and figured I could dump the whole oil in on top of the other 5 gallons, and with the splashing of the fill up, and driving 5+ miles to the boat ramp, I figured it would all get mixed anyways. If I am low on fuel in the tank, or especially if I am filling a tank from dry, I definitely wouldn't put all the oil then fill with gas. I'm trying to be honest here but yeah I got a bit lazy on that half fill up.
I can't see your pictures but you could be fouling plugs.
You may have to sign in to a google account to see since I upload them to google drive, and post the shared link. It seems to work for another member so it may be on your end. I like doing it this way since the images don't clog up the thread. Makes for an easier read and you can open pics you want and skip others. Forums are my life saver for the motorcycles, and even work / electrical questions. I am always amazed at the community of passionate, extremely knowledgeable people who spend their valuable time helping others. Humans are freaking awesome. Well some of us anyways
I would be a little concerned with the 10 psi difference in compression between the cylinders.
I'm going to elaborate more on my question with this in the quote below from the next poster.
First, your spark plugs look like hell. Get some new ones ASAP. On these old skis, you should replace them every year and even twice if you use your ski a lot. With rust like that around the base of the plug, I wonder how old they are.
Yeah I should have ordered new ones right after purchasing. I just got a set of 4 today and swapped them after doing the compression test. 2 new ones in, and 2 spares ready to go if I foul them again (if that is what was happening).
Second, as for compression, I would try another tester just to make sure but 10 PSI diff as @mikidymac said is definitely a bit of concern (I've been through that and it cost me an engine). I bought a cheap tester a couple years ago that was not accurate and I thought my engine was toast. I retested it with an expensive one and everything was OK A1. Don't know about your tester since I am not a mechanics (but I am learning).
Okay here goes ha! So do you truly mean I should be concerned or is it that I should be observing and regularly checking? Concerned is a pretty strong word in the mechanical world. It is usually the precursor to preventative maintenance, which in this case would be ripping apart the jug. When I'm still at 130 psi, and "only" a 10 psi difference, would this really be what I should be doing? If I test it in a couple months and I'm down another 10 psi then I would take action then, but I don't think it is necessary yet...?
Furthermore, I may be mistaken, but what can really go wrong with letting a compression discrepancy linger? Eventually it should get worse, and I'll notice a loss in power / performance and then address at that time. Is there something catastrophic that can happen from a compression discrepancy? Can you elaborate on how you lost an engine due to this?
Third, as for the DESS post, yes, the issue could be intermittent at first but usually it gets worse within a matter of days (after a week, mine became completely unusable). Also, check the inside of your key for the presence metal flakes (clinker?).
No metal flakes, but the inside of the key just looks to be in rough shape, I posted some pictures in a previous post but here is another link.
Yeah the DESS post has me concerned. If I fouled the plugs then I don't think she would start back up 30 seconds later, and I was having the issue where I needed to unplug and replug the key before the starter would crank when it did die. Someone posted on another thread indicating that is a tell tale sign the DESS is starting to go. I think I am going to take her back to the river, and go upriver but not far, then do some circular riding and see how it goes. If she dies on me I can float down and paddle to shore. Last time I was so far away it was a total debacle getting back to the other boat ramp (thanks for uber / lyft).
Fourth, drop this cheap oil, there is no savings in trying to save a few bucks for oil. Some people will also tell you to empty the oil tank before putting the good one and not mix them.
Well there is a savings, but as you and others have mentioned it does not outweigh the potential maintenance and repair work. I am a believer now though, due to apparently mostly the RAVE valves.
