I’m just spit balling but the sandpaper would add to the circumference of the old piston, it definitely wouldn’t be an exact measurement though. How much does the manual say to take of? .010?
Yeah good point!I’m just spit balling but the sandpaper would add to the circumference of the old piston, it definitely wouldn’t be an exact measurement though. How much does the manual say to take of? .010?
Post in thread 'How much to shave 951 RAVE Valves?' How much to shave 951 RAVE Valves?I’m just spit balling but the sandpaper would add to the circumference of the old piston, it definitely wouldn’t be an exact measurement though. How much does the manual say to take of? .010?
Nope this is good! Thank you!Boring out cylinders - 787cc
Not sure if you found this thread or not but Mechanix mentions using a straight edge and feeler gauges to measure the clearance. Anyways sorry for all the replies, you may have to re post your original question to get an answer from someone now, lol. Best of luck, I think you got this
Hey Travis, how did you end up machining rave valves down? If you could post a couple pics and explanation of how you did it, I would sure appreciate it.Yeah seems to have cleared up after a good run. I was just being a wuss
Yeah just used a round file and kept running it on the edges and measuring it. The metal is so soft it comes off real quick. I'll post a pic but yeah it was pretty easy. I think I would do that sandpaper on piston thing next time so it's a little more accurate... You sent me that link earlier to the guy who did it that way...Hey Travis, how did you end up machining rave valves down? If you could post a couple pics and explanation of how you did it, I would sure appreciate it.
Well just looking through the Rave valve port now at the side of the piston... There's definitely some vertical lines (up and down) on the piston. I put a pointy screwdriver down the valve opening just so I could gently feel it but there isn't any depth to the lines(cant feel them) , but there's definitely lines. I got a picture with my inspection cameraYeah just used a round file and kept running it on the edges and measuring it. The metal is so soft it comes off real quick. I'll post a pic but yeah it was pretty easy. I think I would do that sandpaper on piston thing next time so it's a little more accurate... You sent me that link earlier to the guy who did it that way...
You ever here of using ammonia to clean the carbon off the valves? I guess put them in a sandwich bag wrapped in ammonia soaked rags or paper towel and the next morning wipe clean
I was just measuring as I already had the top buttoned up. I know I wish I would have visually inspected that when I had it apart. And as for cleaning them up just used a wire wheel....Thanks Travis, did you go strictly on measuring? Or Were you fitting the rave valve in and then turning the engine over to see if it would hit?
