Ok so recap….propulsion did not seem up to par….motors sounded ok and seemed to rev up to decent rpm’s (gauges work some times, sometimes they don’t)
New drive shaft, drive line rebuild kit and new pump. Old impeller was good so it was installed and clearance was .006. Install went good except for a split in the pto boot on the drive shaft clamp surface, installed hose clamp to hold it and test.
Water test went ….ok, split boot was not a problem, held fine. Propulsion had definite improvement but still seemed lower than I expected. Checked bilge while running everything looked good so decided to run it a while and then re-check so we took a cruise to the far end of The Lake and rechecked the bilge, no water so the new boots, carbon seal and stainless fitting were all working nicely….still wondering why propulsion was not where it should be.
Pulled it out of the water to check things over and noticed when shifter was in neutral port side reverse bucket was fully covering the nozzle but starboard side was covering only the top half of the nozzle, shift into drive and reverse bucket was positioned above the starboard nozzle but on the port side the bucket covered the top half of the nozzle…..
Decided to drop it in the water and make a trailer adjustment the re-load the boat and go home to make adjustments. Wife in the boat (she can’t back the trailer yet) I drop her in and when she fires the port side it begins to rev and move like it is in drive. I motion to kill it then restart, same thing. I dive in and pull the boat by line back to the dock and tie it off. After I make the trailer adjustments I attempt to take the boat out and figure out what was happening.
Port side was at partial throttle when lever was in neutral, starboard ran fine. Drive shifter seemed “tight”. Re-loaded the boat under power from starboard side only and headed home.
Removed the shift controls and WOW! Drive cable mount severely bent and one cable broken, this bent the port side throttle cable mount putting tension on the cable and why it was firing at partial throttle.
So….seems as though propulsion just might be fixed but I won’t know until I replace drive cable and fix mount….Looks like my season is most definitely over...
