Sportster-2001-951C-Stock
I'm at THE lake, you probably know exactly where.
Sure, it's not unusual for oil to seep past worn inner crank seals when the motor sits, the longer it sits the more likely. Good tight inner crank seals won't do this, well worn ones do it quickly and your oil tank contents can disappear into the crankcase if bad enough, some guys put a shutoff valve in the RV supply feed line to stop this during winter but it's stop-gap and if inners are worn that bad there's a chance outers are too and that can roast a piston.
Your bronze pump sure sounds okay to me, some forward/reverse play is normal, there's a thrust bearing and race the impeller pushes/loads the thrust bearing and all this stuff forward as you run water-loaded pump. Look for water inside the hub, if yes then there's a leak, pressure test the cavity to 10psi for 10 minutes. Anyway, I'm in the camp your splines are worn out, check the PTO hub carefully. Put plenty of grease in the splines during reassembly and give them a small drink once in a while b/c hungry grease worms live in there.
Air leaks around pump tunnel and drive shaft allow your impeller to ventilate, some call it cavitate but quickly explained these are two definitions I prefer to differentiate; cavitation involves the negative pressure at which the water "boils" and has nothing to do with air leaking into the pump from poor tunnel seals. Poor fit and condition of impeller and wear ring are culprits for cavitation, serrated edges of impeller blades aggravate this phenomenon.
The only thing I suggest you do back there is pressure check your jet pump oil cavity from the 1/8" pipe thread oil fill port and replace any deteriorated/missing seals that might allow air into low pressure side of the tunnel.
Rung out splines slip and won't transfer torque into the impeller.
I think the plastic pumps might be faster than the bronze ones or is it the other way around, but you gotta be careful with that b/c I think the impellers aren't interchangeable on some of those. Check that, I'm not sure but might be a concern.
Personally, I don't mess with jet skis much, mostly stern drives.
