If you believe this site's definition, Mystik is technically ashless:
http://www.dragonfly75.com/moto/oil.html
100% percent agree with Dan. If you're going to run API 2 stroke oil, mystik jt4 full syn is the way to go. Buy the PWC if you can find it, or you can use the snowmobile oil. It is exactly the same. I have a mom & pop oil distributor in my area that sells a 4-gallon case for $80. Don't care to debate the benefits of API oil or tcw3 or mineral oil.because you can literally google what oil to use and find 4 billion discussions that usually end up as a s*it show with hurt feelings and puffy chests.
I use, and what I recommend to others to use, is Mystik JT4 synthetic. I use it on everything I own.. raves, no raves, RV, reeds, whatever.
Thanks for testing that out, I run the same exact quicksilver PWC oil. I will probably introduce it a little at a time to work it inI've been using the Quicksilver PWC. It's purple. The Mystic is purple as well. I combined a little of both in a mason jar just now. They seemed to mix together just fine. I'm going to let it sit overnight to see if it does anything funky, like separating, spontaneously combusting, etc.I know this isn't an indicator of what they'll do once burned together, but it's an experiment to occupy my mind at least. My oil system is deleted so I don't have to worry about clogging lines and such.
Quicksilver definitely makes a mess that lingers. I am trying to get all the oil out of one of my engines right now(leaking rotary crank seals) and have sprayed quicksilver all over the place.Nothing crazy happened as of this morning. It didn't separate or anything. It's still homogenized.
At first when I saw purple in the Mystik bottle I wondered if they were the same oil with two brand names. But upon closer inspection I found that not to be true. They definitely have different consistencies. I'm not sure that "thinner" is the right term, but the Mystik seems that way for lack of a better term. When I pour it on a flat surface it spreads out faster and becomes more transparent than the QS.
Castrol SuperClean does a great job inside the hulls.Quicksilver definitely makes a mess that lingers. I am trying to get all the oil out of one of my engines right now(leaking rotary crank seals) and have sprayed quicksilver all over the place.
Love the stuff, works well for the outside too!Castrol SuperClean does a great job inside the hulls.
Is that that recommended spec cleaner per SeaDoo? Can you please cite your source?
JUST KIDDING! LOL.
I usually mix it 50/50 with water and spray it anywhere that I get greasy hand prints. My hull is far from the shiniest so it absorbs grease like nothing else.Do you just spray it on, let sit, and then wash out? My bilge is embarrassing.![]()
In the end the Mystic will serve you well and is the correct oil.
Be sure you drain out all the old oil and replace the inline oil filters before switching oil as most oils don't mix well with each other and can clog your oil system and trashing your engines.
So. . . do Mystic JT4 and XPS mix OK, or do you HAVE to drain and replace filters to make this switch? I have been running XPS (new 787 engine) but I like the Mystic price. Can I just switch or should I wait for winter for the change-over when it makes more sense to do the whole drain and clean cycle?
