4. Never start an oil thread.
Excellent advice.
I think he was just poking fun at the reality that oil threads always devolve into a battle of the opinions.Why? Point me to a thread where literally any of the current XPS for QS oil formulations are discussed in an educated manner. I've found literally none. Every oil thread almost exclusively discusses oils that no longer exist.
Completely agree on both points. Youll find most members ignore any post on oil questions for this exact reason. Noone ever agrees, so do your resesarch and use what you are comfortable with.
I also use the Mystic JT4 full syn pwc oil. I bought about 12 gallons at one of the Academy sports sales and got it for around $21 a gallon shipped after sale and rebates.
They have it at the pensacola store, amazingly cheap stuffMan, that Mystic is almost half the cost of what I'm using. I don't see it on Academy's site though ...
I don't know why it isn't on the bottles anymore but seadoo has changed the packaging about 10 times and makes it more confusing each time. I can assure you it is API-TC rated and good to use in your Seadoo. I'll see if I have any old bottles at home that list it. Keep in mind that seadoo actually recommends either their mineral oil or their full synthetic so they really don't need to list the API-TC on their bottles. API-TC rating is listed as an alternative to the seadoo branded oils.Show me where the xps mineral oil is api-tc rated please ...
Or for that matter, any of the ones you listed ...
Or even a statement from Sea-Doo or rotax for the non rave engines requiring api-tc ...
You could do a little research on the ones I listed as see for yourself they are API-TC rated oils...
"Mystik JT-4 Synthetic 2-Cycle Personal Watercraft Engine Oil utilizes premium synthetic base oils combined with a special synthetic additive system to provide superior high temperature oxidation stability and wear protection. Its unique tri-blend of synthetic components provides ideal high temperature performance and quick starts in all temperatures. This balance of synthetic components enhances fuel economy, and improves high temperature thermal and oxidation stability. The special additive system designed for specific use in Personal Watercraft engines provides the best protection against engine wear, rust and corrosion, and ensures engine cleanliness. The advanced formula used in Mystik JT-4 Synthetic 2-Cycle Personal Watercraft Engine Oil far exceeds Personal Watercraft engine requirements for an API TC and JASO FC quality oil."
Here is your proof that the seadoo's require API-TC oil and not to use TCW-3 straight from the owner's manual.
You cannot beat that price. I have been debating switching to Mystic for a while; might have to get a jug and see how some mixes with Mercury.Thanks for those pages. I looked in my manual and do now see where it says to use api-tc if Bombardier Injection Oil isn't available. So I'm glad we have that officially determined now.
API certified oils bear the API seal:
https://motoroilmatters.org/Protect-Your-Car/Learn-About-Standards
None of the oils discussed so far bear that seal. They all merely state that they meet or exceed that specification. XPS doesn't bear the seal or claim to meet the standards.
In addition to changing their packaging, SeaDoo has also changed their formulations. I think the obvious most likely explanation as to why their oils no longer bear the API seal is that they changed their formulation and did not care to pay to have the new formulation certified by the obsolete specification. My only point here is that, if SeaDoo no longer feels the API cert is important, why must we hold any of the others to that same standard? At least many of the others publish their specs! (That comment is directed mainly at any "XPS or die" people.)
Thanks for the offer to find an old bottle but it doesn't have any bearing here IMO since it's likely not what is currently being sold.
I just ran to Academy and got some Mystic, so thanks for that recommendation as well, everyone. $23/gal is a lot better than $40!
it's hit or miss if academy has any around here, which is why I started ordering 6 at a time from the link I sharedYou cannot beat that price. I have been debating switching to Mystic for a while; might have to get a jug and see how some mixes with Mercury.
I think you are missing the point on the API-TC oil...
It doesn't have to have the seal on the bottle and as far back as I can remember to the early 90's never had an API seal like the car oils do.
It just needs to meet or exceed the API-TC spec which all of the ones I have listed clearly state that they do and just as the seadoo manual states that it must meet the API-TC spec. So just because you don't see the seal on the bottle doesn't mean that the spec is no good or the oil doesn't meet the lubrication requirement.
As far as seadoo changing the the oil formula that also isn't correct.. The mineral oil has always been the same from the 90's to today, only the bottle has changed. they also used to have a semi-synthetic that was orange.
The only oil that has changed is the XPS full synthetic as it was first made by Castrol and was gold color then about 10 or so years ago production changed to RedLine oils and it became red in color but it has always held the same specification. Seadoo doesn't make oil, and never has, they contract companies to make it to their specifications which haven't changed.
In the end the Mystic will serve you well and is the correct oil.
Be sure you drain out all the old oil and replace the inline oil filters before switching oil as most oils don't mix well with each other and can clog your oil system and trashing your engines.
You still have to supply oil to your rotary gear though.
I don’t understand why you think the API-TC spec isn’t important.
No, you don’t have to run Seadoo XPS specifically but you still need to run an API-TC oil.
Here are the basics...
1. There is no such thing as a dual rated oil, TCW-3 and API-TC.
2. Seadoo Requires and needs a API-TC rated oil. 587, 650 & 720 only need conventional API-TC so your only option is the Seadoo XPS 2T CARB Mineral. The 580-720 can also run semi-synthetic like the Lucas 2-Cycle oil (NOT Land & Sea) or Full Synthetic like the Amsoil Interceptor or Dominator and Seadoo XPS 2T E-TEC, Mystic JT-4 and . The 787 & 951 have to have full synthetic API-TC.
3. The TCW-3 oils do not have the lubrication or film strength of an API-TC oil. This has proven to cause rotary valve scuffing and piston damage in the seadoo engines. This has also proven to cause inner crank seal leaks in 580-787 engines and piston failures in the DI engines.
Prices... per gallon.
XPS Carb 2T $27.99
XPS 2T E-TEC $42.50
Lucas 2-Cycle $30.00
Mystic JT-4 $25
Amsiol Interceptor $45
Amsoil Dominator $51
The big takeaway from all of this is don’t run TCW-3 oil in your Seadoo.
If it’s a 580-720 run the Seadoo Carb 2T or any of the others listed above. If it’s a 787 or 951 you have to run full synthetic API-TC equivalent oil. Hopefully we can all agree on this.
