95 gtx wont start.
KingKoopa562
i have a 95 gtx im trying to get running but i cant figure out if its seized or not… it turnes over and wants to start wen i take the spark plugs out ..but wen i put them back on it will turn over once or twice then seize up..
no oil comes out just a bit of smoke .. im assuming batteries are good … i have 2 gtx’s ill switch batteries with the other one and see what happens.. i charge them regularly but they are 3 yrs old .. idk the lifespan on them .. but ill give it a shot ..keep u guys posted thanx
Yea, lifespan of powersports batteries can vary. Some are no good when they are new, and I’ve had one that lasted 8 years. I’ve seen a lot of people saying mid not to leave them in the tender, just put them on a 2amp charge every couple of months when not in use and store them in a cool spot. If you have a multimeter check the volts at the battery while cranking
