nikdseadoo
You don't need to run it fyi. The water pressure from hose is plenty. Someone can correct if I'm wrong.Ok thanks,
Next time I run it I will let it go a little bit longer. I only let the hose run 10 seconds or so.
Full send....It's already back together, going to get on the water this weekend!Pump seems ok. I’m not sure what the ring to impeller tolerance measurement is. Looks like ya got lucky. Change oil and send it!
No, this was a small plastic shim or something that sat on top of the wear ring. The wear ring itself looked fine.Did your wear ring blow apart or is it an aftermarket one?
Oil pump is gone, I am running pre-mixIs your oil pump functioning?
40:1What ratio?
Well that's a serious bummer. Let me reach out to the rebuild shop and see what they think.That engine is done. It will not run in the water with the compression that low.
130 is perfect on a 951.
Man I sure hope thats not your compression. Was the tank completely empty of fuel when you added the pre mix fuel? I find it wildly unlikely on that short ride you'd have hurt the motor. It it a good reputable compression gauge? Holding throttle wide open? Crank till the gauge stops?
With out going back did you rebuild carbs and test pop off etc?
You sound like my 951 a week ago. I took the carbs back off and rebuilt the freshly rebuilt carbs, only the second time I listened and used all mikuni parts.
I rebuilt them over the winter over the course of a couple weeks and I don't think I ever tested the pop off.i used genuine mikuni kits and everything went good, no issues with any of the internals.Thats fine, so long as each is with in 10% of each other. I gotta read back through thread but the carbs you built them and tested pop off etc?
