megalodon4g63
Got a 2001 Sea Doo LRV with a blown motor. Ordered a 2002 Sea Doo RX DI 951 on ebay and this 951 looks a lot different. From what I understand it should interchange with the XP and GTX 951/947 models. Am I wrong or did I just buy something that will not fit my application. I'm new to PWC and learning, so go easy. Also, if anyone has a wiring and vacuum line/water line schematic for the 2001 LRV it would be helpful. In addition to the same schematics for a 2001 Sea Doo GTX RFI with a 787 motor. I know, lots of requests from a newbie, sorry.
I attached pictures, not sure which order they will post.
Also, when you look at the pictures, what the heck is that little piston looking thing that seems to move up and down on the left of the newer block? The other motor doesn't have this. I'm hoping this could be blocked off or something. There are so many more vacuum ports on the new engine. Can any of these be plugged or re-routed to allow me to use this engine? I may also need a vacuum line schematic for the 2002 Sea Doo RX DI 951 as well so I could see where the vacuum lines went on the new engine and what they supplied. I'm thinking they could've been oil lines, not sure. I'm looking at the small ports that seem too supply the lower crank case.
safe to assume that I cannot accomplish this task unless I had the DI computer, injectors, and sensors. I figure I'd be able to block off some of the vacuum ports and maybe make it work hoping I didn't waste money on something I didn't need. Maybe I could swap heads, I dunno.
