I've been having electrical problems & my manual says "If battery is regularly discharged, check this fuse condition. Fuses for the charging system are located at the starter relay in the engine compartment".
I've located SOME fuses in the engine compartment & verified they are not blown - in the attached picture I've circled where I've checked the fuses.
Can anyone tell me where the "starter relay is"?
Thanks!!
Problems are dead/near dead battery, voltage light is coming on, engine cutting out & one long beep while driving (not at start), engine stalls when throttled back. I have a second battery as backup - basically I "recharge" my starting battery by hooking them up in parallel for a few minutes & then disconnect the 2nd battery to get the boat to turn over. Curiously, the boat does *not* turn over when both batteries are connected, which seems odd to me.
Thanks!!
