vegaschef364
Hello, I am trying to figure out why my gtx won't start. It turned over and started fine earlier in the summer then sat for a couple months and when I got back it wouldn't start. I press the start button the lcd lights up, put the key in get the 2 beeps, it reads normal key in and when I press start again I get nothing, no click or anything. I have replaced the battery, starter, and all the fuses, including this one but looking at it I'm thinking I was given the wrong one. The one on the top is original, the one on the bottom is new, and this seems like a dumb question but I know very little about fuses. Is it the correct replacement, the diagrams on the 2 are different. There was quite a bit of corrosion on this fuse and the box, and a little bit on the other fuses in that box that I cleaned up, the other box looked good. But that aside, I have been told it is the ECU which I am really hoping it is not. Does anybody have any ideas of where to start? Before I replaced the starter I did do the jump test on the solenoid in the manual and got nothing. The compartment did get flooded at the beginning of the season but I cleaned it all out, got all the water out, changed the oil and plugs and ran it. It ran a little rough at first but it was running fine when I left.
