That spark plug on the right is not firing. You were running on only 2 cylinders. Did you ever try just replacing the plugs?It did start to rain but before I tested the battery at 12.38, removed approx. 8 ounces of oil and the spark plugs. Had to cover everything up right as I was about to check compression
I also managed to free up a millimeter or so of play on one of the pump bolts before the battery of the drill got taxed
Here are some pics of the oil, I dropped some on a white background to show clarity and the plugs 1,2, and 3 from right to left
Chester
