SHESAH
is the throttle cable installed in the wrong hole on throttle body cam ?
I'm not sure what I was doing wrong.. I shut everything off and started over.
that is low for this engine
battery fully charged?
should have about 300 RPM on cranking.
if you shut some oil down the plug hole and do compression again and see what it increases too. This will tell you top or bottom end issue.
How many hours on it ?
non super charged you looking at around 150psi compression
yes
should be between the two marks , but don't think that will affect compression
battery should be higher than 12 around 12.6 especially a new battery
That's definitely too much oil, although it shouldn't affect compression. Your compression is low as well. Gazzaskirepair is correct, try dropping a teaspoon of oil into the cylinder and run the compression test again.
The oil looks pretty dark for being fresh. Does it smell like gas by any chance?
The supercharger has slip washers in it that should not allow it to spin easily when attempting to spin by hand.
The correct/precise way to check the amount of slippage can be found HERE, but I'd hold off on that check until you've ruled out some other things first, but definitely try to move the impeller by hand. If it spins easily, then your supercharger is in need of a rebuild.
Check the rpm when cranking
You should get around 300RPM
Have you had a look at the jet pump drive shaft and pump inlet for anything wrapped around shaft and anything in pump inlet ![]()
Once you get that pump off, post some pics. Lets see those plugs too. IIRC you stated the plugs and oil were changed recently. Do you know how many hours you put on the boat since the change?
Did you have a chance to recheck your compression numbers with a little oil added to each cylinder?
So looks like no noticeable increase with oil in chamber ?
So you could get away doing a head job but to confirm this a Leak Down test would identify which valves are leaking
As the ski hasn’t been used in 3 years and it doesn’t cost anything except labour it’s a good idea to remove jet pump to lubricate shaft splines and get a bass to start from on what condition it’s in
I am in the line of thinking you have sh1t on the valve seats hence no power under load
I’d say leave it together and get the jet pump off to check
get all the problems first then go forward
Confirm is it a supercharged engine ? The engine May get better compression wise once your able to to get it above the initial 4800 as it’s been standing for 3 years
I have just picked up a boat not used for about 4 years 215hp supercharged and avg 135 psi
Hours are 255 so age is just a number
