Hello again and thanks in advance for putting up w/ the newb questions...
We plan on getting a 3-seater for playing around on the lake w/ the kids while using in conjunction w/ our pontoon; have a budget of $5k at the upper range - also considering a sportier 2-seater in addition to the 3-seater if the right deal can be found and stay in budget.
I'm an old gearhead and familiar with prop boats but would appreciate some insight as to what to look for when inspecting used PWC's.
I've been told it's highly recommended to actually ride the ski so it's under load for testing - Is it 'absolutely' necessary to actually ride or if you test the cylinder compression will that alleviate the bulk of the concerns?
- Besides verifying a strong motor is there any other purpose of test driving? I assume verifying the pump / impeller / wear ring is part of the test drive procedure. Is it just the wear ring and possible impeller nicks that are a concern?
(Doesn't seem that hard or expensive to replace the wear ring and something required over time anyway).
- If a motor has decent / matched compression and passes visual inspection am I reasonably safe purchasing without a test drive if it's convenient to do so?
- I've googled 'Inspecting used PWC' already and done some reading but would appreciate any available input.
Right now I'm thinking of going w/ a 2-stroke for lower up front cost and cheaper replacement parts as needed; I'm also not at all against finding a ski w/ a bad motor and replacing it myself w/ a re-manufactured motor.
Also - What's the Small Block Chevy of 2-strokes (apologies to the Mopar and Blue Oval crowd
)? ie: What motor is relatively reliable? Easy to work on? Parts available at a fair price?
So far it seams that the 951 while have excellent power-to-weight ratio seams to be prone to a shorter life span and the 787 seams to be held in pretty high regard; or is it a case where the 951 has generally been used more in the hot rod XD style boats and thus more prone to abuse or ridden harder by younger crowds?
- That being we are waiting on a response from a gentleman that has two GTX-DI's; they look nice from the ad but should we be leery of the 951 motor?
EDIT: What's the story and concern w/ grey fuel lines? Is it just a matter of changing out the lines or do the grey lines cause problems down stream with the carbs or injectors?
Thanks again,
Steve
Thanks again,
Steve
