Sportster-2001-951C-Stock
What are those?
For measuring precision tolerances in less than 30 seconds, handy to have a set!
http://www.urbandictionary.com/define.php?term=bch
What are those?
just a heads up for those of you that are auto mechanics that have a 1 3/16" inner tie rod socket for removing the tie rod from the steering rack will work perfectly for the vts nut.
I've never worked on the 951, can someone post a pic of this infamous nut on the 951?
A little late to post this, but here's the lil' f'er.However, nobody gets to look at like this, apart & upside down on the bench.....
Still don't understand why the manual calls for lubricant on the threads rather than loctite.
For something that is known to get loose & leak, it seems odd to me.........
Lubricant, eh? I like the loctite idea better.
Does anyone use a 1/4 drive air ratchet on their seadoos? I'm thinking of trying one out, there are many times that I can get a ratchet in a spot but there is very little room to crank it.
Yep, mine is for the 2" gauge nut in the XP hoods, same idea me and JetSkiGoodies collaborated on it, as seen here:
http://www.seadooforum.com/showthre...t-Gauge-Removal-Tool&highlight=gauge+nut+tool
Yes, a Beer is a good calming tool....... It would appear you already drank it tho....... A Yuengling? Never had one......
Lol, Now I just need to figure out the Blue cover......
Hhhmmmmmmm, a jar of peanuts? Peanuts go good with cold Beer.![]()
Fantastic! Do I get to drive the GTS around for a week? Or at least get a ride??![]()
Not really, I was just reaching a bit.
I was referring to your Ferrari GTS..... I see your PI skills have diminished a little.....![]()
