Rich1983
Had one of those days where everything has been going wrong, heres the problems iv'e had today:
Put a new starter on one engine last week and it worked great, I only put it on hand tight to test etc and it was good with the engine starting great.
Today I pulled it off and put some grease on the spindles and the top part to seal it around the block then re-assembled it with everything tight then I press the start button, it clicks and struggles to turn the engine very slowly. Pulled it off again, stripped it and couldn't see anything out of place. Tested it while it wasn't bolted it and it engaged and spins great but again once it's bolted into the engine its barely turning the engine over. Any suggestions? Have I possibly killed it by using grease on it? or possibly a faulty starter?
Second problem/concern, Got both air boxes off as I was adjusting the throttle+choke cables to find that on one engine when I pull the throttle arm on the carb it sprays fuel into the manifold which Id expect is normal. But on the other engine if I pull the throttle arm theres no fuel being sprayed into the manifold!! Any suggestions on this?
And last but not least, I had one engine fired up briefly which has supposedly been recently rebuilt with all new internals. It start, cuts out on idle and there wasn't much smoke so turned it off immediately after about 5-10 seconds of spluttering and bogging.
When it was running it sounded very dry, as if the crank bearings were noisy and grainy type sound. Could this be a simple case of the crank bearings are completely shot?
Also is there a way I can check if the bearings and seals are ok without stripping the engine? The engine has been sitting for a good year before I bought the boat and this is the first time its been started since. I did put a few drops of oil down the plug hole and into the carb before starting it.
Iv'e checked the pump and it all seems to be working and set good. If I start the engine again and hold the pump lever on full to get maximum oil in, could this possible help the bearings and stop the noise?
