2003 sportster le no spark
DTH357
I bought this boat last year, and it would start and run fine. Then the motor locked up, and I bought one that had just been rebuilt out of a 1998 xp. I swapped over the exhaust manifold, and the rear pto coupler. Installed it in the boat, hooked everything up, and it will spin over just fine just don't have any spark at the plugs. I removed the engine, and swapped the front cover with the old cover and stator. I then reinstalled the engine, hooked everything back up, and still no spark at the plugs. I checked all the fuses, and all the grounds, and everything is fine. I just can't figure out why I don't have spark, when I had it before.
I'm back to let everybody know what the problem was. It was the flywheel. Seadoo changed something on the flywheel from a1998 to a 2003, and the ECM couldn't read it. So I changed the flywheel, and everything went to working correctly. Maybe this information will help somebody having the same problem.
