just needs some help...
Have had leaks all over the exhaust system, had to get the 'bung' welded, then reclaimped, etc... worked well for a while, then the exahust bolts came loose. Lost two bolts, had to get new ones and new gasket, that's fine now...
Not seeing any leaks from the PTO (though its older and doesn't have the carbon ring... no more leaks on the exhaust/manifold, nor do I see in the expansion pipe, and I tightened everything into the exhaust box, and don't see anything coming in, but the bildge keeps filling with warm water.
thoughts?
thoughts?
