henryb
I finally got the new Mercury outboard compatible Water Temp gauge from Crowley. It is a 60-200F range gauge, as I have read our engines run cool around 120F or so.
The installation went smooth, I followed the wiring instructions carefully, it lights up, but it doesn't seem to read the temp from the pre-wired tan wire in the helm? Not exactly sure how to test it, if the temp sender is working or not? What voltages should I be getting from that wire to ground?
