RobNY11563
I've seen some posts on this (most of them closed). My jetski is down in FL and I'm down at most once per month, sometimes it can be every other month. During 'longer' periods when I'm not there, I had an issue where the battery alarm would sound when I first started the jetski, although never did it not start. So, I had started using a solar trickle charger which ultimately eliminated the battery alarm sound.
The solar trickle charger 'claims' to not overcharge....and clearly it cannot charge at night or even all times of day as it's not in direct sun all day. My question is, is it okay to leave that connected for weeks on end? I can go 4-8 weeks (or more) where I'm not able to ride. Is it better to just not use a trickle charger and do it as needed when I go down.....I don't want to degrade the life of the battery, yet I used to get the battery alarm sound prior to a trickle charger.
Also to note, my battery only lasted 2 years and died recently (out on the ocean) so it's being replaced. My friend who stores his jetski next to mine as well, also uses a trickle charger and his battery is 100% fine even when load tested in recent service.
