Rosie2514
Have a weird one here. So the last time i took out my ski to the river she ran awesome like usual. Starts easy, idles fine, no hesititation, 58 mph. The last time at the river i ran her most of the day and when my fuel guage was just below half a tank she just randomly dies during WOT. She then would start right back up but would only pull about 6200 RPM instead of the normal 6750. As i would keep riding it would slowly get worse to where it would maybe hit 5500 RPM then die. Then start back up again and run for maybe 100 yards then die, and STAY dead. after getting hauled in that day on the river I had a few beers and hung around then pressed the start button only for her to gargle and spray quite a bit of water out the exhaust. Once i got her home and on the charger she would crank up fine ?
So this past weekend i took it to the lake for the first time and she did the same exact thing!! Ran good the whole day until i got below half a tank then would die to a stop, then restart and run and steadily drop RPM then just die again and not restart. Once i got her home from the lake i hooked up the charger again and she sprayed the same amount of water out the exhaust(quite a bit) then finally started and now starts fine like always? What is the deal?? im lost?
Carbs were cleaned at beginning of summer. Fuel lines also changed. Plugs look fine!(maybe a hair lean on MAG side but i adjusted an 1/8 of turn on high and it seemed to help last time. Whats the deal? any help appreciated
