Colseadoo1955
I am doing a baseline rebuild on my 1997 Seadoo GSI 717. As my factory digital gauge is bad and nearly impossible to find for these rare GSIs, I would like to just install some new analog gauges and wire them up, i.e. by-passing the MPEC. This engine has a temperature sensor on top of the head between the two spark plugs that apparently affects a ground for something, either an indicator on my digital gauge (that again is bad), or a warning buzzer or maybe even an emergency shutdown. I would like to know if I can use this sensor or a substitute that will fit the threads for the analog temp gauge. Does anyone had advice on this and maybe know what temperature range that sensor should run at? I have the same basic question regarding the factory oil sensor which has me confused anyway as there is some sort of "roller" on the end of this sensor and I haven't a clue how that thing works.
