alexd51
I will. Thanks.On the counter balance side of the motor at the PTO end you will see a cap with a flat head screw slot. Make sure the motor is level and open that cap. Stick a zip tie end down in the hole and pull it out like a dip stick. You should see oil on it. If not then add 1oz. 30 weight oil.
