I got a stone in my Seadoo Spark Trixx 2018, once again. I was changing the wear ring but noticed this time also the small black tube got destroyed. I went through all the drawings I could not identify it and googled a lot but simply could not find an answer what that thing is and what part to order. It is at 11 o'clock when you look from the rear after you have removed the impeller. I have attached few photos.
When you put back the whole thing (impeller pump) you just need to make sure the tube goes into the hole in the "impeller body". The strange thing is that the hole does not seem to lead anywhere because it is plugged. You can see that black hexagon plug. But I am little worried to put the jetski back in water with an uknown whole in the back...
Any advice welcome, thanks.
