ID62
Hi, just a quick information for those who has trouble with there speedometer. Mine wasn't working but I had a good signal from the paddle-wheel. When you spin it you must have a signal between 5 and 8 Volts. But you have to power-up your boat, means the DESS key must be in. Also you've to check if you have 12 volts at the plus wire on your speedometer.
If this is OK then it might be the same problem then I had. The connecting bolts are made from brass. There isn't a good connecting between those and the PC-board from the speedometer. I had a kind of corrosion between the bolts and the contact pads on the PCB. I opened the speedometer and removed the corrosion. After this assemble the whole device again but don't mount the glass and the aluminum ring. First you have to connect the speedometer to your boat and power it up. The needle is moving to the 0-point when it gets the power. Then you have to adjust the needle. Once you did this, it's the time to close your speedometer with the glass and the ring. This is the shitty work on it, because you have to border crimp the aluminum ring. But it saves your money ;-)
BR
Ingo
BR
Ingo
