1998 Gtx Rfi been smoking alot on startup - killed all mosquitos in Michigan.
So after sitting for a day I pulled the plugs and hit start - got lots of gas out of front cylinder mixed with some oil - soaked 3 rags.
So I removed the fuel rail let it sit overnight.
Turned it over today and got - what I consider - too much oil out of front cylinder.
Fuel pressure on fuel line is 55-60 psi, compression on both cylinders is 125-130 psi.
If this is bad seals on valve crank...why am I only getting excess oil building up in the front cylinder?
I am fairly mechanically inclined but new to Seadoos.
I am taking the injectors in to be re-calibrated and cleaned.
Thanks.
Thanks.
