Significantly Oily Water in Bilge
gpotavin
Hi All,
I’m new to posting here so go easy on me :)
I have a 2008 Sea-Doo Speedster 200 boat. This year after taking off the shrink wrap and putting it in the water for the first use of the season I noticed the bulge pump was dumping oily water out. I took it back and they checked it over claiming the tech had probably spilled oil when it was winterized so they cleaned & pressure washed the bilge. Last weekend the oil light came on and the alarm was going off. Bilge full of oily water again.
Any thoughts? Cracked block from not being winterized correctly by them last year? Thanks.
Have you checked each motor for the oil level?
Yes, the starboard engine was off the dipstick the first time I took it back and it’s the same now. I asked them to check the seal on oil filter the first time around and they claim to have checked it and said it was properly seated.
Check the oil cooler and the lines leading to and from it on the lower starboard side of the motor.
Why do you have so much water in your bilge?
It will be easier to find the oil leak of you can find the water leak.
