The starboard motor would not turn over when the start button was pushed, then when I connect the port side ignition the 5a fuse pops within seconds of connecting it with the key on.
I replaced the starboard starter relay 1st and the motor would crank and run fine. Then when I went to crank the portside the 5a fuse blew within a few seconds and neither motor would run with this fuse blown. Thought it could not hurt to replace the other starter relay although I did not think it would fix the problem. To my surprise problem fixed...
