Seadoo speedster jet boat
Yes it’s a 2-stroke.
No oil pump won’t flood the engine. From your symptoms it’s the inner crank seals that leek from the rotary cavity and the only permanent fix is to replace the crankshaft.
A temporary fix is to put a shutoff valve on the 12mm oil lines from the tank to the intake side of the crankcase.
There’s no PTO jet.
Front (MAG) carb
Main 140
Pilot 67.5
High speed screw 0
Low speed screw 1-1/2
Rear (PTO) Carb
Main 142.5
Pilot 67.5
HS screw 0
LS Screw 1-1/2.
These are the jets I pulled out of the set of carbs on one motor
Well 4 of them one is a double up, what do you think I should replace them with, were these the wrong jets in here, according to your jet sizes you posted me I just want to make sure I all of the right ones thanks so much for your help
You can look at the parts diagram for your exact year and model and it will tell you what jets to use.
Being a little bigger on the main jet like you have won’t hurt anything.
To determine the front carb, is this the carb facing the front of the boat and which jets go which 145 and 67.5 front and 140 and 67,5 rear is this correct
MAG is the front of the engine towards the front of the boat. PTO is the rear of the engine towards the back of the boat.
Could you be kind enough to verify what the jets are in the front and back carburettor
Seadoo Speedster 787
Just open the carburettor kit and wondering what these two items are for, can you help
On the left are the o-rings for the high and low speed adjustment screws.
The two on the right hold the fuel pump mylar check valves down.
Do I have the Mylar check valves on this boat and if so where are they
Okay great thanks for that I am just working on both carburettors now and they don’t appear to have gaskets under the plates they just have the O-ring type does this sound correct to you I guess the gaskets supplied must be for another sort
I’m pretty much standing in front of the carburettor and just want to ask you one more time, if the mag carb is 145 and the PTO carb is 140 in the main jets and then the primary are 67.5 I just can’t seem to find your last post
Can you confirm that both cameras at 145
Can someone please put in the right direction to find a carburettor breakdown diagram for a Seadoo speedster 1999 twin engine 2 stroke
I have looked at the diagram on this website and this seems to be the incorrect one my carbs don’t have the rectangle gaskets only the rubber inner gasket.
Front (MAG) carb
Main 140
Pilot 67.5
High speed screw 0
Rear (PTO) Carb
Main 142.5
Pilot 67.5
HS screw 0
LS Screw 1-1/2.
The rear (PTO) carb without the fuel pump only uses the rubber o-ring, no paper gasket.
Front (MAG) carb
Main 140
Pilot 67.5
High speed screw 0
Rear (PTO) Carb
Main 142.5
Pilot 67.5
HS screw 0
LS Screw 1-1/2.
Great thank you very much for this I really appreciate it look I’m looking at joining to be a full member premium paid option can you please inform me that I will be able to get information on my boat is when looking into it I am a little confused on the section where the says SpeedStar with different codes I actually can’t see my boat there could you please inform me possibly what model number My boat would be
Seadoo speedster 787 twin engines two stroke 1999
As the Carburettor details don’t look to be my one
