Mine has never smoked this bad. Typically I get the normal cloud when we first start it at the launch ramp, but then it clears up after running for a few minutes.anyone? to those of you who have a 240, can you confirm that this smoke is not normal? I really would appreciate any help - thanks again
IAlso, am I missing something in the manual section or is there nothing for the 2000 and 2001 mercury motors (shop manual)? I only see the 2002..
Know this is late but mine does not smoke at all even idle with a hose attachedanyone? to those of you who have a 240, can you confirm that this smoke is not normal? I really would appreciate any help - thanks again
This certainly sounds like the problem. I've read a couple of your replies on this thread and yours seems to make the most sense. Is there a link on how to do this test? I have a tough time finding someone to service this motor here in the Vancouver, BC area, so will probably test it myself.It looks like your engine is "loading up" with fuel. That is, too much fuel and that means also too much oil. Why? Where is it coming from? What is your fuel pressure? Should be 35-37psi. When you get your test gauge connected, turn key on, engine off. What is the pressure? Turn key off. How long does it take for pressure to drop to zero? Instantly or several seconds? If instant- you probably have one or more leaking injectors that will dump too much gas into the engine. Too much pressure? Another way for too much fuel dumped into engine. See a pattern here?
Have read through the manual now but need to grab the injector pressure gauge. Do you know if an automotive pressure testing kit like this is suitable? DASBET 0-140PSI Fuel Injector Injection Pump Pressure Tester Gauge Kit Car Tools, Fuel Pressure Testers - Amazon CanadaExplained in sevice book. You need the shadetree mechanic's injector pressure gage.
Very few shops will work on our boats. Those that do, seem to just throw (YOUR) money at the problem and and hope something sticks. What is the definition of a boat?
So I finally received the fuel compression gauge. It did not have the adaptor for the merc 240 engine, so I sent it back and got another. Fuel pressure check out fine. 34 PSI with key on. After reading more forum decided to check the throttle position sensor. Using the sewing needles and a multimeter, i get .207 volts at idle and .759 at open throttle. this seems within range according to the manual.That is more sophisticated (more adapters) for less than mine. Should work for you.
Anything else you think I should check before I hang upside down for a long time to get the injectors out and then serviced? I replaced the air temperature sensor as I had a new one on hand. We did replace the head temperature sensor a couple of years back, but could check that as well. We did use a budget semi-synthetic 2-stroke oil for a few years before we realized you were supposed to use synthetic Quicksilver or equivalent, so perhaps that could have caused some issue with the injectors? Thanks!
