shendershot731
At work just stewing about my problem.
-I did notice that one spark plug was alot warmer than the other.
- when at 3k rpm on the water the engine will die if the choke is pulled doesn't fix the problem so I don't think I am running to lean.
- when on the water it won't go above 3k rpm. if I hold it long enough it will start to back fire I can feel it, so it seems like I am getting to much fuel as it is making its way to the exhaust then firing. Is this correct thought on this?
- I tried to not mess with the LS adjuster it should run right at stock.
so Tried LS adjuster from a range of 1/2 to 1 to 1.5 turns out no difference except on the smooth Idle.
- I don't really want to give up on this thing, but I am afraid it is a engine leak issue somewhere.
- I started with a box of parts and put this thing together I am proud of the fact that it runs, I just want it to run right.
- when I pull the spark plugs out they are black and wet so Still tells me to much fuel.
- I did try a different set of NGK spark plugs and same result.
- out of the water it will rev up to 5k rpm but it is stuttering and backfiring.
- I am tempted to just buy a new engine for $1000 and drop it in, but it seems like it should be something simple like a fuel circuit not opening on one of the carbs. I need to check the Exhaust hose again I took off one end and not the other it could be it.
- anyone have a video on how to sync the carbs youtube is sucking for those things lately?
