Seadoo 951 x4 build
Getting some more work done to night....slow but trying to stay at it. Had to do some cutting to get the pipe in . Ill test fit it in the morning....
Well got the pipe hitting on one side. Im working on getting the engine perfectly aligned now and see what I need to trim and damn this sucks!
Got some more done. Im working on stand blasting the engine right now to powder coat and build. I need some help. Can I run a case cooler with out it hitting anything? Thanks again guys
Working on sandblasting as well in the mean time....more parts on order to do the duct work for the pipe...
Getting more work done! Water box all fixed up. Doing a lot of sand blasting so I can powder coat everything.
As much work as you have done might as well have moved the exhaust outlet to the other side. Didn't you paint the bottom of the hull ?
