Lay under the ski and look in the intake grate. You will be able to see if anything has been sucked in there. If all clear, hook up water and start the engine. Then turn the water on to flush. Only run for a minute at the most. Then turn water off, then engine off.
Never have the water running without the engine started. I usually just turn the water on halfway.
