Just bought my first seadoo...a 1994 GTX. Hadn't been started in years, but it has decent compression 125/130, and it started right up with fresh fuel. Put it in the water yesterday...and it barely crept forward at full throttle! I could have paddled faster with my hands.
I pulled the pump housing and drive shaft...the shaft splines are fine...there's as much as .014 gap at the wear ring (which has some rough chew marks forward of the impeller)...and the leading edges of the impeller are somewhat dinged up....so is the wear my problem? It's also not pumping water at the indicator (unless I have it hooked to a hose...and pinch the main line)
TIA for any help!
TIA for any help!
