reverse gate adjustment
Sailfish
okay here is yet another noob question my reverse gate on the driver side motor is lower then the other how do i adjust it up to match the other my boat has been pulling to the right and i hope this adjustment will fix it thanks for the help
My 95 speedster also pulls to the left... I noticed if I give the port engine more power it no longer pulled. I'm thinking I need to check the impeller wear ring this winter to see if that's the problem.... after you do your adjustments, the next time you have it on the water, try fussing with the throttles.... (I'm assuming you have two engines on that boat)
probably aint the "right" wat t fix, but if decided "not" to pull levers' assy out and adjust cable there or at inside engine compartment at hull, "if applicable", then what about adjusting "left-side" gate, to match???:eek:
Reverse Gate
i dont want the gate on the left to hang over my jet pump nozzle .....i alrady have the lever assembly undone so i will look for an adjustment there and the exit point of the cable at the rear transom thanks bro
