LeeZeitvogel
I was at the dock refueling after an hour drive down the coast. I went to fill it up and I was able to pump in about 2 gallons and gas spit back out the hole like it was full. So I stopped a second and then kept refueling. When I was finished I went to crank up my boat and It was VERY hard to start, I tried about 10 to 15 times. (Note I had this problem before but not this bad so I replaced the temp sensor and put some injector cleaner in it this summer). I checked the gas cap to see if it was tight and I opened up the throttle in hopes that it might let out some gas fumes because it might be flooded. After about 10 minutes it finally cranked, after turning it over for about 20 seconds and it was not a strong start. I then left the dock and got on the throttle and it sounded like there was some slipping going on, like when you have a clutch going out on a car (rpm's but no get up and go). So I idled back at 10 to 15 mph and took her home. I checked the impeller to see if I had something in it and there was about a hand full of fishing line around the drive shaft that I had to cut out. So do you think the starting problem could be related to the propulsion problem? And is the fishing line my only worries? I haven't had time to take her out since I cleared the line out but I am dying to know because all I see is dollar signs when stuff like this happens Also when I went home to flush it out it cranked up fine but it had time to cool off too. ?
