97explorer717
I think I already know the answer but I'm going to ask anyway. The plan was originally to disassemble, clean, rering and reassemble. Purchased current engine running from wrecked ski. Actually purchased from a repair shop. Owner told me he wouldn't do anything but put it in and run it. Guy had run his ski into a bridge. When I got it home I started thinking about where somebody had started to sandblast it to paint. Really started worrying about the fact that they sandblast it around the rotary bath feed with no plug. As suspected when I cracked the bottom half off the case guess what was in there. That's a rhetorical question. So it's been sitting all winter and I thought it's time to get on it. Cylinders are stock and walls are not bad in the jugs. BUT I'm concerned about the crank of course. When I spin the bearings, best I can describe it as it's like a roller skate wheel. So is this to be expected on a used motor? I already know the response to replace it completely rebuild it and that puts me back to where I was with the previous motor. I'll be what 900 to 1,000 or more in with no warranty if I do it myself. If that's the case I might as well just spend a couple hundred more and get a short block. I figured around 300 with new Pistons, rings, wrist pins, bearings and gaskets. Maybe just ball hone the cylinders and go with it. Anybody's advice or incite will be appreciated. It's a 787, carb out of a ski going in my Challenger. Figured I may get more responses here thinking that the engine question doesn't matter if it's a boat or not. Thanks!!!
