More detail later, but a quick update...
I was busy with last minute taxes Saturday morning, so I wasn't feeling motivated to install the jet pump. However, a friend came over Saturday night to help me and we got it all back together. Thanks Kicker for your thoughts on alignment. We took out the aft shims under the engine mounts and it lined up perfectly.
Sunday my friend picked me up and we took his new home made cloth over bamboo canoe (rather awesome) and the Challenger to a local lake to see how bad they leaked.
The plan was to run the Challenger on the trailer and leave with a list of things that leaked that would need addressed before I took it out "for real". I left the engine cover hatch at home so I could see the engine while running.
The trailer was backed in a little far... half of the swim platform was under water. The exhaust and speedo ports had a slow trickle leaks, but nothing else leaked. I choked it and it fired up pretty quickly, but wouldn't idle consistently. Pulled the plugs and they were wet. Stopped using the choke (was only using it to start, not when running) and it gradually ran better. I was concerned at how smoky it was running. I knew it would smoke, but wasn't prepared for that much smoke. I had forgot that I squirted a little oil in the cylinders last week to ease the initial starting. With the bilge fan on it wasn't that bad, but I had it off initially so I could hear what the engine sounded like.
Once it settled in and was idling reliably we pulled it out, drained the little bit of water that had leaked into the bilge, took off the trailer straps, and got the boat in the water off the trailer.
First time out we just idled around the no wake area by the boat ramp. When I tried to speed up past idle the throttle was stuck and wouldn't advance, so back to the boat ramp dock to pull the throttle assembly and look at it. All looked fine and my buddy figured out that if you push the Forward lever all the way forward, that it unlocked the throttle. I probably should have re-read the operators manual before this trip.:facepalm:
With that figured out, we headed back out. It idled smoothly out past the no wake markers, then as I slowly increased the throttle it would sputter... so back to idle. I kept doing that routine and it gradually got more smooth at higher rpms. It did die a few times, but seemed to be getting smoother every time I bumped up the throttle a bit. Eventually it was running smoothly enough to get up on plane.
HOLY CRAP! This thing is AWESOME!
I varied the speed a LOT and only got up to full RPM for a few brief moments here and there. We rode around for an hour or so. Every now and then it would sputter and die, mainly when at planing speed. My buddy and I were thinking that the gas is from mid August, so it may be old enough to cause some poor performance. I put Stabil in it in December, but it was already a bit old. I can't get the fuel filter open to clean it or replace the element, so I'll likely remove it from the boat this week so I can either get it open or replace it.
Doh! Gotta go to a Dr. appointment, but I'll share why we ended up paddling back to the boat ramp later. :willy_nilly:
Here is a video of my friend driving, with me and my son riding.
10 points to the person that correctly identifies from the video the clue of the problem that caused us to paddle shortly after this video. :blush:
http://youtu.be/loNUh39YxYc
