mejim707
So yesterday I pulled apart the fuel system;
1. I removed all hoses (they were not the gray tempo ones just old crusty ones).
2. I removed and inspected the pickup, it was perfectly clean. And the float and gas gauge work.
3. I removed the fuel selector. I could blow air through it and it worked as expected in the 3 modes, On, Off, Reserve.
4. I checked the return lines. There are two tie wraps at the "Y" of the return. That's the only place I would expect the air to intrude since everything else was locked down with proper hose clamps.
5. I pressurized the tank a bit, not to the full 5PSI because I have about half a tank, but the pressure did hold. I'm going to fill the tank today and pressurize to 5PSI to be 100% confident there is no air leak for a potential of air intrusion.
This all brought me to happening upon something as I looked over the parts diagram. I was reading the part names then saw that the pulse hose was called a "formed hose". This took me down a path researching the pulse hose.
The one I have is a clear, flexible and flimsy hose that's responsible for the pulse. I never thought anything of it because this is the hose the previous owner had on it so I thought this was normal until I saw that name on the parts list.
After researching I find out that hose needs to be a strong, reinforced hose or it could kink / collapse and prevent proper pulse to the carbs!!!!
COULD THIS BE MY ISSUE ALL ALONG??
If the hose I have is super flexible, and already has a small kink in it just sitting there, then when the engine is hot it would totally make that hose super flexible. Couldn't that absolutely prevent a pulse to the pump in the carbs?
So.. with that said, I'm going to finalize the fuel line replacements today and I'm going to take a piece of the strong fuel line I have and replace that flimsy pulse hose.
Depending on weather, I'm going to try this out today or tomorrow morning at 6am. I don't know if this is it, but it sure seems like this could be.
Thoughts from the gurus would be awesome!
Thanks!
Thanks!
