garrettcollins27
Hey guys, I am coming here for some help with a recent problem.
I have a 2003 Utopia 205 with a Merc 240hp EFI. #OE412646
2 weeks ago I was out and I started getting the 4 beeps every 2 minutes. Both the oil tanks were full and I was getting oil pressure out the cap of the motor mounted reservoir. So I emptied the fuel separator and installed a new oil sensor. Took the boat back out and it ran fine for about 20 minutes then I got the solid beep and the boat went into guardian mode. I am now going to try and replace the oil reservoir on the motor and change out the temp sensor. I did notice the left side of the exhaust had some burning to it. im not sure if it was that way when I bought it or if this just happened. Just wondering if im on the right track changing the reservoir and temp sensor. It flushes fine on the hose I get a good amount of water out of the impeller and out both exhausts. I was thinking the other thing to check is if there is any blockage in my lines but im unsure on which lines I need to check. TIA for the help.
