I think I am done with the oil bypass.
First off I really need to thank everyone for their input, especially Dr. Honda. I did not have him come over and give me a hand, but what a great guy to offer with all the things he has going on. I know you are all jealous that I live near him!!!
I have been considering this change for over a year, and I must admit that I was intimidated by the job. It was not as easy for me as it seemed for the others, but I am sure that if I had to do it again it would go much smoother. I hated the feeling of failure so I went back at it today after work.
A couple of points for anyone attempting this job...
1. The back bolt for the oil pump is difficult to access. It could have been the positioning of the fuel lines and my inability to get a direct shot at it, but I did eventually get it off with an 8mm socket. After it was removed I left the hoses in position and plugged with bolts, and disconnected the throttle link. (Do I need to do anything with the link on the lower end?)
2. You need to loosen the unit with the vapor separator in order to remove the metal drive gear and replace it with the blockoff plug. This requires an allen wrench (don't recall the size) and it was a challenge to acces at least 1 of the 3 bolts. I had to lift up the engine oil reservoir to gain access.
3. When you put the blockoff plug in it seemed to fit in with no issue (O - ring included), but I must have had it in the opposite direction, because my screws were off. I turned it 180 degrees and the screws lined up so I must be ok.
4. I removed the bottom hose (found below the water separator filter) without issue and replaced it with the brass plug which took 1/4" allen key.
5. I removed the screw on the vapor separator unit (maybe I am saying the wrong part, but this is silver and infront of the oil injection pump), and drained all fuel out of this area.
6. I always drain my water separator filter at the end of the season, but I added some oil to a 50:1 fuel mix directly into the filter.
7. I had nearly 40 gallons of stabilized fuel in the tank, so I mixed the appropriate amount of oil to make 50:1 for 40 gallons in 4 5-gallon tanks. I siphoned approximately 20 gallons of fuel, mixed and dumped back into the tank.
8. It got dark, so I need to do the adjustment to the oil alarm with the hose holding the float up, so it does not sound. My question is, if I leave the oil I have in the engine oil reservoir, will it keep the alarm from sounding?
I did not attempt to start the boat today. I will give it a few days.
If I missed anything or need to do anything else, please let me know.
Thanks again,
Brian
