Oil help/question
03stage2
I know my boat has always had the 2 stroke sea-doo brand mineral oil and I also understand you shouldnt mix if you switch types. My dilemma is I can order the mineral oil but it wont be here in time to play this weekend. I cant find anyone locally who sells the mineral oil. Is there anything else I can use and mix with the sea-doo oil or am I out of luck?
Also if I have no luck finding oil how long do you think half a tank will last me?
Thx much!
Do you not have a dealer close?
Its a risk to do so....
you have plenty of oil that oil tank is over 2 gallons (according to google) so you should have at least one gallon of oil go out and have a nice weekend !
i'm not a speedster owner but i'm guessing you are good for 50 gallons of fuel.
Mine has been on half a tank for the last three trips out. Out for at least three hours each time and it's barely went down any. I would order it from Amazon and go out n play, just keep an eye on it.
At full throttle, it will get you through a full tank of gas. It's a 2 gallon oil tank and 40 gallon gas tank and it mixes 40:1 at full throttle.
I see you are running mineral oil, I thought the 787 engines should only be run on synthetic?
