If the battery is dead... putting it on the charger won't help. Sounds like the battery needs replaced.
But... you know the drill... make sure the drive-line can spin free.
Thanks Dr.! I did that "before" you even said it
, im getting good at this DOC, lol, removed the plastic nuts covering the PTO, and it moved freely...
Guess what? I played around with the negative wire (moved it around a bit), and bam, it started turning with the plugs out, now, I know this thing likes good gasoline, so the gas in there is 9 months old.. no bueno.... plus its kinda low on gas, so I moved it to reserve gas, threw gasoline in the holes, the same ritual over and over again.. untill.. finally I got it started, I left it on a good while (by pulling the choke, and giving it some gas), after a while i turned it off..
The biggest concern I have now Doc, is that 3 times it acted like there
wasnt any electricity at all??? It didnt do absolulety anything, no red lights, nada,.. I then tightened the battery cables, moved the red and black cables from the MPEM (just moved it around), and finally got some electricity flowing again.. thats creepy? what can that be?
