Hi guys first of all i am a newbie from Greece and i am sorry for my english. I have a 2002 sea doo 717 .
Ski runs fine on trailer, idles smooth and revs up and down without a problem. Put it in the water, and it's hard to start. If you get it started, it will only idle. Engine does not rev any higher, RPMs stay around 1500 even with the throttle fully squeezed. If you hold it at WOT for a few seconds the engine bogs and dies. Pull it out of the water, and it starts and revs fine again.
Sometimes you can get it to kick and start running at full speed 35-40 mph, but as soon as you let go of WOT it will die and won't start again. Plugs seem to have too much fuel ( and oil mix ?)on them when pulled out, seems like possibly running too rich. Hi and low speed mix screws are at stock settings. I have change allready the piston with new 82.5 mm , bored cylinders , rebuilt the crankschaft ( all seals , bearings ) and carb rebuilt but except needles . I mess the rotary valve clearance ( 0.30 mm ) and i think the rotary valve is timing correct .
If you have any ideas please respont !!!
